CHT temps, individual cylinder differences? |
falcor75 |
Apr 12 2018, 10:50 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
For those of you that are running 4 CHT sensors under the plugs, what differences do you see between the cylinders?
Whats your typical temps for each cylinder with: A: Engine warmed up sitting at idle for a minute or two. B: Engine warmed up, cruising at 50-55 mph in fifth gear. |
jd74914 |
Apr 15 2018, 08:22 PM
Its alive Group: Members Posts: 4,779 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
What is your target AFR? Or do you have a screen shot of your map?
That's a pretty big difference in fueling at idle given the airflow differences. Assuming you are at lambda = 1 for cyl. 1 airflows, you'd be at about lamba = 1.3 for cyl. 2 at idle. That's certainly enough fuel to cause some additional cooling and result in those lower temperatures. You could see lower flows if you have some valve adjust or pushrod length issues (not opening enough) or a flat cam lobe. I'd guess the cam is OK since your motor is pretty new. Were your injectors all flow mapped or checked? I've seen some new injectors pretty far off the mark. If they haven't been tested it might be interesting to swap them between cylinders and see if the temperature mapping moves. |
Lo-Fi Version | Time is now: 26th April 2024 - 05:49 PM |
