CHT temps, individual cylinder differences? |
falcor75 |
Apr 12 2018, 10:50 PM
Senior Member Group: Members Posts: 1,578 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
For those of you that are running 4 CHT sensors under the plugs, what differences do you see between the cylinders?
Whats your typical temps for each cylinder with: A: Engine warmed up sitting at idle for a minute or two. B: Engine warmed up, cruising at 50-55 mph in fifth gear. |
jcd914 |
Apr 20 2018, 11:25 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
After reading through this and your struggles to get the air flow balanced for each cylinder.
Do your throttle bodies not have an air bypass screw for each cylinder? This is benn the standard on carbs for years and I have not seen a throttle body that did not have balance screws. I can't say that I have seen a lot of throttle bodies up close but I have seen and adjusted a few. What brand and model of throttle bodies do you have? At least the cylinder that is different is running cooler and not hotter that the others. Jim |
Lo-Fi Version | Time is now: 29th March 2024 - 07:25 AM |
