CHT temps, individual cylinder differences? |
falcor75 |
Apr 12 2018, 10:50 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
For those of you that are running 4 CHT sensors under the plugs, what differences do you see between the cylinders?
Whats your typical temps for each cylinder with: A: Engine warmed up sitting at idle for a minute or two. B: Engine warmed up, cruising at 50-55 mph in fifth gear. |
falcor75 |
Apr 20 2018, 11:42 PM
Yes I'm not sure there's any fault with the throttle body.
Might be the cylinder or valve train, guess I need to make a compression check or leakdown test. Its just such a bother since the space is sooooo tight I'll have to take the throttle bodies and manifolds out. |
Lo-Fi Version | Time is now: 20th April 2024 - 01:23 AM |
