shifter restoration? |
doug_b_928 |
Apr 13 2018, 09:01 AM
Senior Member Group: Members Posts: 691 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
It's unseasonably cold here so no work on the car outside yet (IMG:style_emoticons/default/sad.gif). Figured maybe I'll work inside on the shifter this weekend. I didn't see a thread on restoring the shifter. Is this something that just requires a good cleaning, or should it be disassembled, cleaned, painted, and new grease added? Pics of mine below.
rhodyguy |
Apr 13 2018, 11:10 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Put a vicegrip on a spring, remove the 4 circlips, push the 2 pins out and remove the springs. This method prevents the springs from flying across the garage. this is what the detention plate should look like. straight across the re-inforcing plate on the underside. as they wear, the center of the plate gets wallowed out and there usually is a gouge on the shift lever. adding the loss of material on the lever and a spent plate it is certainly is of no help setting the linkage.
The backing plate has slight bevel. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 24th April 2024 - 04:48 PM |
