shifter restoration? |
doug_b_928 |
Apr 13 2018, 09:01 AM
Senior Member Group: Members Posts: 689 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
It's unseasonably cold here so no work on the car outside yet (IMG:style_emoticons/default/sad.gif). Figured maybe I'll work inside on the shifter this weekend. I didn't see a thread on restoring the shifter. Is this something that just requires a good cleaning, or should it be disassembled, cleaned, painted, and new grease added? Pics of mine below.
mepstein |
Apr 17 2018, 06:56 PM
914-6 GT in waiting Group: Members Posts: 19,234 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You start with the screwdriver about 1/4” in where the pin goes, put the spring on the screwdriver. Put the pin in the other end about 1/4”. Bend the end of the spring down so it’s held in on each side, screwdriver and pin. Grab the spring in the middle with the vise grips, lock them and push it down. Shove the pin through so it pushes the screwdriver out. It’s good to have the vise grips clamped down as you tension the spring so you have good control if the spring.
Leather gloves and eye protection. |
Lo-Fi Version | Time is now: 23rd April 2024 - 10:05 AM |
