Another distributor, Question #2? |
shane |
Apr 14 2018, 11:25 AM
Member Group: Members Posts: 355 Joined: 12-February 13 Member No.: 15,518 Region Association: None |
Hi, I don't have original distributor and have stock 1.8/with single carb. Am in the middle of going through the whole car and replacing parts. Am looking for a good choice for a distributor for not to much money. Have read the svda 034 is a good choice for a general purpose dizzy? Looking on eBay at "hot spark" brand but not to many reviews. Any thoughts would be appreciated thanks.
IronHillRestorations |
Apr 14 2018, 11:43 AM
I. I. R. C. Group: Members Posts: 6,707 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Do you know what distributor is currently installed? If by any luck you've got a stock 1.8 dist, that's the best one for carbs IMHO.
The Pertronix distributor only work well with the Pertronix Ignitor, and don't do well converted back to points. You want to make sure you get the correct coil for the Ignitor you are getting, you've got to match the ohms |
rhodyguy |
Apr 14 2018, 11:50 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,042 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
I imagine there's a L-jet dist somewhere in the greater Puyallup area. I know of a couple near canyon road.
jdamiano |
Apr 14 2018, 12:04 PM
Member Group: Members Posts: 335 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States |
I just put a Pertronix distributor and coil on my dual Weber 2.0 and found it easy to install and the car runs fine. 160.00 for both on Amazon.
Mueller |
Apr 14 2018, 12:32 PM
Are you replacing the single carb?
For the distributor, run the part number for it. It might be a decent or acceptable unit that only needs cleaning and some internal part replacements instead of swapping out the entire assembly. |
98101 |
Apr 14 2018, 07:53 PM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
If I don't have to drive to Puyallup I'd be happy to just give you my Bosch 009. But I don't recommend it.
shane |
Apr 15 2018, 09:22 AM
Thanks!!!! from your guys good advice it sounds like for now I should just throw a stock one in the hole.
shane |
Apr 15 2018, 09:27 AM
Are you replacing the single carb? For the distributor, run the part number for it. It might be a decent or acceptable unit that only needs cleaning and some internal part replacements instead of swapping out the entire assembly. Not at the moment but have all the injection system will instal it after I finish about a million other things on the car. I know the carb set up I have sucks but it works. |
Lo-Fi Version | Time is now: 28th March 2024 - 08:39 AM |
