Is this an OEM oil line |
PanelBilly |
Apr 15 2018, 09:29 AM
914 Guru Group: Members Posts: 5,796 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Steve |
Apr 15 2018, 10:17 AM
914 Guru Group: Members Posts: 5,565 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I’m having trouble mounting my new heat exchanger on the passenger side because the oil line that comes out of the case is in the way. Ben said I should be using a stock line. Anybody have a photo I can compare this with? That loooks like my oil line from PMS. PMS takes a stock 911 return line, cuts off the end and welds on an an-12 fitting. Mine also rubbed on Bens heat exchanger. I had to take off the clamp, loosen the nut and push the line against the case. Everything was tight but still fit and I was able to put on the heat exchanger with no leaks. I will replace this line with a steel braided line this summer. |
Lo-Fi Version | Time is now: 19th April 2024 - 04:39 AM |
