Is this an OEM oil line |
PanelBilly |
Apr 15 2018, 09:29 AM
914 Guru Group: Members Posts: 5,797 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
mb911 |
Apr 15 2018, 10:04 AM
914 Guru Group: Members Posts: 6,811 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Yes.. My supply of these should be ready soon and I could ship you one to try
Most guys are using stainless braided lines. Mark Epstein has a really clean setup with good pictures. |
mepstein |
Apr 15 2018, 11:36 AM
914-6 GT in waiting Group: Members Posts: 19,239 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Yes.. My supply of these should be ready soon and I could ship you one to try Most guys are using stainless braided lines. Mark Epstein has a really clean setup with good pictures. I tried to make my pms conversion hard line work with the heat exchangers. I didn’t. It worked fine with headers but no room with the he’s. I made stainless steel lines and it fit easily. I bought a kool tool to make the lines and it went from a pita to very easy. Ben’s hardline is very nice but I was routing the line from the engine up the passenger long so using the steel line with an a/n fitting worked best for me. |
porschetub |
Apr 15 2018, 03:56 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Yes.. My supply of these should be ready soon and I could ship you one to try Most guys are using stainless braided lines. Mark Epstein has a really clean setup with good pictures. I tried to make my pms conversion hard line work with the heat exchangers. I didn’t. It worked fine with headers but no room with the he’s. I made stainless steel lines and it fit easily. I bought a kool tool to make the lines and it went from a pita to very easy. Ben’s hardline is very nice but I was routing the line from the engine up the passenger long so using the steel line with an a/n fitting worked best for me. Marks correct saying using a hose as being a good solution,if the OP isn't going this way you could buy the full length pipe from Pelican for about 30 odd dollars and bend it to clear,this pipe is plated copper and very soft,cut it down and refit the end to suit the hose length to the tank. I used this pipe and bend it so it lined up with my bracket on the case and was tucked up as high as possible out of harms way. Also I'am sure Ben could assist with some better solution. |
mb911 |
Apr 15 2018, 04:23 PM
Yes.. My supply of these should be ready soon and I could ship you one to try Most guys are using stainless braided lines. Mark Epstein has a really clean setup with good pictures. I tried to make my pms conversion hard line work with the heat exchangers. I didn’t. It worked fine with headers but no room with the he’s. I made stainless steel lines and it fit easily. I bought a kool tool to make the lines and it went from a pita to very easy. Ben’s hardline is very nice but I was routing the line from the engine up the passenger long so using the steel line with an a/n fitting worked best for me. Marks correct saying using a hose as being a good solution,if the OP isn't going this way you could buy the full length pipe from Pelican for about 30 odd dollars and bend it to clear,this pipe is plated copper and very soft,cut it down and refit the end to suit the hose length to the tank. I used this pipe and bend it so it lined up with my bracket on the case and was tucked up as high as possible out of harms way. Also I'am sure Ben could assist with some better solution. That looks like a brand new hardline OE? Those are $300 plus if you can find them.. Thats why I had them remade larger as they were nla |
porschetub |
Apr 15 2018, 06:23 PM
Yes.. My supply of these should be ready soon and I could ship you one to try Most guys are using stainless braided lines. Mark Epstein has a really clean setup with good pictures. I tried to make my pms conversion hard line work with the heat exchangers. I didn’t. It worked fine with headers but no room with the he’s. I made stainless steel lines and it fit easily. I bought a kool tool to make the lines and it went from a pita to very easy. Ben’s hardline is very nice but I was routing the line from the engine up the passenger long so using the steel line with an a/n fitting worked best for me. Marks correct saying using a hose as being a good solution,if the OP isn't going this way you could buy the full length pipe from Pelican for about 30 odd dollars and bend it to clear,this pipe is plated copper and very soft,cut it down and refit the end to suit the hose length to the tank. I used this pipe and bend it so it lined up with my bracket on the case and was tucked up as high as possible out of harms way. Also I'am sure Ben could assist with some better solution. That looks like a brand new hardline OE? Those are $300 plus if you can find them.. Thats why I had them remade larger as they were nla No Ben I'am sorry now think it was around $70 ,got it from Pelican for that price or there abouts,that was a while back and see they now list same OEM part for $104,it came from a 75 911S,I had cut the curved end off and sweated the fitting back so it went straight to my tank. |
Lo-Fi Version | Time is now: 25th April 2024 - 08:59 PM |
