Fitting Condenser Wire Insulator into 009 Distributor Body, Fitting New Condenser |
motorvated |
Apr 15 2018, 10:52 AM
Member Group: Members Posts: 279 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
I'm replacing the points and condenser on my '75 1.8 with L Jet and the black rubber insulator on the green wire that is supposed to fit in the square hole on the side of the 009 distributor body is too hard to push into the hole. Last time I encountered this I trimmed the ears off of the rubber insulator and used some silicone sealant to secure the insulator in the hole. Not the best solution. Anybody have an easy way to get the rubber insulator into the hole without cutting it up?
porschetub |
Apr 15 2018, 03:07 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
There should be a metal retaining bracket that fits on the condenser screw then into the slot in the plastic piece to hold the wires in place...do you have that?
Lo-Fi Version | Time is now: 5th May 2024 - 01:40 AM |
