Fitting Condenser Wire Insulator into 009 Distributor Body, Fitting New Condenser |
motorvated |
Apr 15 2018, 10:52 AM
Member Group: Members Posts: 279 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
I'm replacing the points and condenser on my '75 1.8 with L Jet and the black rubber insulator on the green wire that is supposed to fit in the square hole on the side of the 009 distributor body is too hard to push into the hole. Last time I encountered this I trimmed the ears off of the rubber insulator and used some silicone sealant to secure the insulator in the hole. Not the best solution. Anybody have an easy way to get the rubber insulator into the hole without cutting it up?
Dave_Darling |
Apr 15 2018, 09:35 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
It is a flat piece of metal with two prongs, sort of like a two-pronged fork. The two prongs slide into the grooves on the sides of the plastic plug, and a mounting screw goes through a hole near the other end of the piece. There is a step in the middle of the piece so that the fork end sits a little out from the body of the distributor.
--DD |
Lo-Fi Version | Time is now: 3rd May 2024 - 05:53 PM |
