Ideas On Auxiliary Heating Systems, Using Headers but Want Heat! |
MikeInMunich |
Apr 20 2018, 12:15 AM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Greetings once again from Munich!
It’s cold over here when the sun goes down, not to mention nice days in March, April, October and November. I need heat, and I don’t have it because my engine has headers. I am thinking I will need a high output alternator if I’m using only 12v in order to get the necessary output. Is this somehow a bad idea? (IMG:style_emoticons/default/idea.gif) Questions: How would a e.g. 50 amp alternator affect power and gas mileage? Would it have any effect on the electrical system? Can you recommend a heater for this application? Other suggestions on how to best get heat into the cabin without heat exchangers? Here is an article on PTC (positive thermal coefficient) heaters... https://link.springer.com/content/pdf/10.10...-11628-5_51.pdf Thanks for your feedback and advice! Mike in Munich (IMG:style_emoticons/default/smilie_flagge6.gif) |
Mark Henry |
Apr 22 2018, 09:28 AM
I looked at why a Tesla doesn't use a heat pump, apparently an auto would have a major icing issue due to moisture, rain, snow, etc. Tesla uses basically a water heater to heat coolant.
You could do something similar with an Espar hot box, where you heat coolant. You would of course still have to plumb it, need a heater core, diesel tank, coolant tank,etc, etc, but the hose would be much smaller lines to run. |
Lo-Fi Version | Time is now: 20th May 2024 - 03:59 AM |
