Ideas On Auxiliary Heating Systems, Using Headers but Want Heat! |
MikeInMunich |
Apr 20 2018, 12:15 AM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Greetings once again from Munich!
It’s cold over here when the sun goes down, not to mention nice days in March, April, October and November. I need heat, and I don’t have it because my engine has headers. I am thinking I will need a high output alternator if I’m using only 12v in order to get the necessary output. Is this somehow a bad idea? (IMG:style_emoticons/default/idea.gif) Questions: How would a e.g. 50 amp alternator affect power and gas mileage? Would it have any effect on the electrical system? Can you recommend a heater for this application? Other suggestions on how to best get heat into the cabin without heat exchangers? Here is an article on PTC (positive thermal coefficient) heaters... https://link.springer.com/content/pdf/10.10...-11628-5_51.pdf Thanks for your feedback and advice! Mike in Munich (IMG:style_emoticons/default/smilie_flagge6.gif) |
edwin |
Apr 23 2018, 08:02 AM
Member Group: Members Posts: 321 Joined: 20-May 09 From: Australia Member No.: 10,384 Region Association: Australia and New Zealand |
I've been seriously considering buying one of the Webasto style diesel heaters out of china.
Slightly less to go wrong than a cheap petrol heater. 2kw normaly advertise less than 0.5L/hr which means most of us could use a tiny 1-2L aux tank and be comfy for hours. Did I mention they are less than $300 of our slightly more useless Australian dollars? https://www.ebay.com.au/itm/12V-2KW-Diesel-...vYAAOSwMhda1wMk |
Lo-Fi Version | Time is now: 20th May 2024 - 01:20 AM |
