Ideas On Auxiliary Heating Systems, Using Headers but Want Heat! |
MikeInMunich |
Apr 20 2018, 12:15 AM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Greetings once again from Munich!
It’s cold over here when the sun goes down, not to mention nice days in March, April, October and November. I need heat, and I don’t have it because my engine has headers. I am thinking I will need a high output alternator if I’m using only 12v in order to get the necessary output. Is this somehow a bad idea? (IMG:style_emoticons/default/idea.gif) Questions: How would a e.g. 50 amp alternator affect power and gas mileage? Would it have any effect on the electrical system? Can you recommend a heater for this application? Other suggestions on how to best get heat into the cabin without heat exchangers? Here is an article on PTC (positive thermal coefficient) heaters... https://link.springer.com/content/pdf/10.10...-11628-5_51.pdf Thanks for your feedback and advice! Mike in Munich (IMG:style_emoticons/default/smilie_flagge6.gif) |
porschetub |
Apr 22 2018, 02:56 AM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I researched this extensively for my car...not that I really will need it.
Small motorhome diesel powered unit would be a possibility and would only require a very small fuel tank as these units are efficient ,I haven't really checked these out fully however. My early tests involved using my A/C in my late model Audi to demist and then the ambient cool air ,both worked....I won't move ice/frost from the screen but that's not an issue for me,my setup directs all the air from the airbox fan to my screen with the option to feed air out the kneepad vents in the summer. No real easy answers really without heat-exchangers. |
Lo-Fi Version | Time is now: 9th May 2024 - 01:16 PM |
