Ideas On Auxiliary Heating Systems, Using Headers but Want Heat! |
MikeInMunich |
Apr 20 2018, 12:15 AM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Greetings once again from Munich!
It’s cold over here when the sun goes down, not to mention nice days in March, April, October and November. I need heat, and I don’t have it because my engine has headers. I am thinking I will need a high output alternator if I’m using only 12v in order to get the necessary output. Is this somehow a bad idea? (IMG:style_emoticons/default/idea.gif) Questions: How would a e.g. 50 amp alternator affect power and gas mileage? Would it have any effect on the electrical system? Can you recommend a heater for this application? Other suggestions on how to best get heat into the cabin without heat exchangers? Here is an article on PTC (positive thermal coefficient) heaters... https://link.springer.com/content/pdf/10.10...-11628-5_51.pdf Thanks for your feedback and advice! Mike in Munich (IMG:style_emoticons/default/smilie_flagge6.gif) |
mepstein |
Apr 24 2018, 10:28 AM
914-6 GT in waiting Group: Members Posts: 19,258 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I don’t understand why guys don’t like the ss heat exchangers. Jake Raby said they are good for up to 165-170hp engines. They are totally bolt on, reasonably priced and replacement parts are available. The system is light weight and works great.
Mblizzard |
Apr 24 2018, 11:59 AM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
I don’t understand why guys don’t like the ss heat exchangers. Jake Raby said they are good for up to 165-170hp engines. They are totally bolt on, reasonably priced and replacement parts are available. The system is light weight and works great. That's what I am running now. I am OK with the heat they make but it could be better and you always have that engine smell in the car. I just think there might be a way to solve it for people that don't have heat for what ever reason. So I have ordered some of the parts and will see if this is even possible. |
Lo-Fi Version | Time is now: 9th May 2024 - 01:40 AM |
