> Ideas On Auxiliary Heating Systems, Using Headers but Want Heat!
MikeInMunich
post Apr 20 2018, 12:15 AM
Greetings once again from Munich!
It’s cold over here when the sun goes down, not to mention nice days in March, April, October and November. I need heat, and I don’t have it because my engine has headers.
I am thinking I will need a high output alternator if I’m using only 12v in order to get the necessary output.
Is this somehow a bad idea? (IMG:style_emoticons/default/idea.gif)
Questions:
How would a e.g. 50 amp alternator affect power and gas mileage?
Would it have any effect on the electrical system?
Can you recommend a heater for this application?
Other suggestions on how to best get heat into the cabin without heat exchangers?
Here is an article on PTC (positive thermal coefficient) heaters...
https://link.springer.com/content/pdf/10.10...-11628-5_51.pdf
Thanks for your feedback and advice!
Mike in Munich
(IMG:style_emoticons/default/smilie_flagge6.gif)
post Apr 24 2018, 10:28 AM
914-6 GT in waiting
I don’t understand why guys don’t like the ss heat exchangers. Jake Raby said they are good for up to 165-170hp engines. They are totally bolt on, reasonably priced and replacement parts are available. The system is light weight and works great.
post Apr 27 2018, 01:14 PM
Michael in Seattle
QUOTE(mepstein @ Apr 24 2018, 09:28 AM) *
I've been advised that the 1 5/8" headers that came with my car are part of why the engine is underperforming for a 2366. (Chris F's opinion here:
http://www.914world.com/bbs2/index.php?s=&...t&p=2567229
So I'm intrigued by Jake Raby's statement, since I'd love to have heat and defog next winter. Wouldn't I lose more power by going to ss heat exchangers intended for a stock engine?
Mark Henry
post Apr 27 2018, 02:49 PM
that's what I do!
QUOTE(98101 @ Apr 27 2018, 03:14 PM) *
I don't think that quote is correct, for HP Jake always said a proper sized header makes the most power. Ballpark 5% for stock to 15+% on a performance engine. A 180hp engine could lose 25hp with small 1-3/8" ID heat exchangers.
A header is the greatest bolt on HP you can add to your 914.
MikeInMunich   Ideas On Auxiliary Heating Systems   Apr 20 2018, 12:15 AM
dansvan   Gas powered Webasto or Espar?   Apr 20 2018, 12:49 AM
MikeInMunich   Gas powered Webasto or Espar? Yes, good options...   Apr 20 2018, 01:31 AM
SirAndy   Gas powered Webasto or Espar? :agree: http://ww...   Apr 21 2018, 08:53 PM
Mark Henry   Gas powered Webasto or Espar? :agree: http://w...   Apr 27 2018, 10:57 AM
sb914   Heated seats !   Apr 20 2018, 05:57 AM
Cairo94507   Heated seats and Ben's heat exchangers.   Apr 20 2018, 06:24 AM
mepstein   Every year guys talk about the gas fired heaters b...   Apr 20 2018, 06:30 AM
Mark Henry   Every year guys talk about the gas fired heaters ...   Apr 20 2018, 07:13 AM
porschetub   Played with electric,didn't spend a lot (lucki...   Apr 20 2018, 05:14 PM
MikeInMunich   Played with electric,didn't spend a lot (luck...   Apr 21 2018, 01:24 AM
Mark Henry   Played with electric,didn't spend a lot (luc...   Apr 21 2018, 06:36 AM
dansvan   The webasto and espar units while not cheap, fit i...   Apr 20 2018, 05:28 PM
98101   I'm in a similar situation. Thinking about th...   Apr 21 2018, 01:10 AM
Luke M   What are the water cooled conv. guys running? Wond...   Apr 21 2018, 07:25 AM
jim_hoyland   Warmer clothes ? Layer up... :poke:   Apr 21 2018, 07:35 AM
Luke M   Warmer clothes ? Layer up... :poke: Lol.. may...   Apr 21 2018, 07:43 AM
Rand   Warmer clothes ? Layer up... :poke: Lol.. mayb...   Apr 24 2018, 03:01 PM
98101   Seriously? 40s? You mean above freezing or below?...   Apr 25 2018, 08:47 PM
Dave_Darling   In my Miata, having a good heater means I can lea...   Apr 26 2018, 10:13 AM
mepstein   In my Miata, having a good heater means I can le...   Apr 26 2018, 11:11 AM
Edward Blume   Heh, I still remember getting pulled over by a c...   Apr 27 2018, 04:12 AM
Rand   Seriously? 40s? You mean above freezing or below...   Apr 26 2018, 04:03 PM
MikeInMunich   [quote name='98101' post='2602870' date='Apr 25 2...   Apr 27 2018, 01:28 AM
Mblizzard   [quote name='Rand' post='2603074' date='Apr 26 20...   Apr 27 2018, 10:21 AM
Dave_Darling   So 12v and e.g. 100 amps from a high output alter...   Apr 27 2018, 11:19 AM
worn   So 12v and e.g. 100 amps from a high output alte...   Apr 27 2018, 11:33 AM
mepstein   [quote name='Dave_Darling' post='2603335' date='A...   Apr 27 2018, 11:54 AM
worn   buy a heated seat pad. plug it into power outlet....   Apr 27 2018, 12:13 PM
Mark Henry   Oil isn't the greatest for heat transfer, you ...   Apr 21 2018, 08:05 AM
GeorgeRud   I was also searching for heat options for my 914-6...   Apr 21 2018, 12:02 PM
Dave_Darling   If you're handy at fabrication, you may be abl...   Apr 21 2018, 12:33 PM
porschetub   I researched this extensively for my car...not tha...   Apr 22 2018, 02:56 AM
Mark Henry   I looked at why a Tesla doesn't use a heat pum...   Apr 22 2018, 09:28 AM
edwin   I've been seriously considering buying one of ...   Apr 23 2018, 08:02 AM
Mblizzard   While you lose some of the instant heat, I would g...   Apr 23 2018, 02:25 PM
Dave_Darling   While you lose some of the instant heat, I would ...   Apr 24 2018, 08:36 AM
Mblizzard   While you lose some of the instant heat, I would...   Apr 24 2018, 11:51 AM
Dave_Darling   OK so I am not sure I see a connection. Are you s...   Apr 24 2018, 08:22 PM
Mblizzard   OK so I am not sure I see a connection. Are you ...   Apr 25 2018, 06:41 AM
98101   You are correct on the delay! Not sure that I...   Apr 25 2018, 08:33 PM
SirAndy   but the point is that for most of us the oil-fed h...   Apr 26 2018, 12:57 PM
Edward Blume   While you lose some of the instant heat, I would...   Apr 26 2018, 05:11 AM
McMark   Is your car 4cyl? Cause I can get you a 250amp al...   Apr 23 2018, 02:29 PM
Mblizzard   Is your car 4cyl? Cause I can get you a 250amp a...   Apr 23 2018, 05:51 PM
mepstein   Different year, same thread.   Apr 23 2018, 06:42 PM
mepstein   I don’t understand why guys don’t like the ss ...   Apr 24 2018, 10:28 AM
Mblizzard   I don’t understand why guys don’t like the ss...   Apr 24 2018, 11:59 AM
mepstein   I don’t understand why guys don’t like the s...   Apr 24 2018, 12:07 PM
Mblizzard   [quote name='Mblizzard' post='2602448' date='Apr ...   Apr 24 2018, 01:04 PM
98101   I don’t understand why guys don’t like the ss...   Apr 27 2018, 01:14 PM
Mark Henry   I don’t understand why guys don’t like the s...   Apr 27 2018, 02:49 PM
Garland   For me, it was around 40 years old, when I started...   Apr 25 2018, 10:26 PM
wysri9   For my stripped competition/road car I am going fo...   Apr 26 2018, 02:25 AM
Dave_Darling   I believe I didn't say either of those things....   Apr 26 2018, 03:41 PM
GeorgeRud   Maybe Ben (mb911) would make some if there was eno...   Apr 28 2018, 01:36 PM
larryM   ... perhaps fabricating some outer envelopes over...   Apr 29 2018, 03:27 PM
76-914   It was interesting to hear Scott? @PMS speak to th...   Apr 28 2018, 05:55 PM
theer   I have a water cooled conversion and never run th...   Apr 29 2018, 04:37 PM
- Lo-Fi Version Time is now: 9th May 2024 - 02:57 AM
