Ideas On Auxiliary Heating Systems, Using Headers but Want Heat! |
MikeInMunich |
Apr 20 2018, 12:15 AM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Greetings once again from Munich!
It’s cold over here when the sun goes down, not to mention nice days in March, April, October and November. I need heat, and I don’t have it because my engine has headers. I am thinking I will need a high output alternator if I’m using only 12v in order to get the necessary output. Is this somehow a bad idea? (IMG:style_emoticons/default/idea.gif) Questions: How would a e.g. 50 amp alternator affect power and gas mileage? Would it have any effect on the electrical system? Can you recommend a heater for this application? Other suggestions on how to best get heat into the cabin without heat exchangers? Here is an article on PTC (positive thermal coefficient) heaters... https://link.springer.com/content/pdf/10.10...-11628-5_51.pdf Thanks for your feedback and advice! Mike in Munich (IMG:style_emoticons/default/smilie_flagge6.gif) |
theer |
Apr 29 2018, 04:37 PM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
I have a water cooled conversion and never run the heat unless it's below freezing. Otherwise, I need to roll down a window to blend in some cold air. Before you make any attempt to add heat or AC seal and insulate! Replace the old door seals if they're torn, the old roof seals and plug any holes in the bulkhead including old worn grommets. (IMG:style_emoticons/default/beerchug.gif) Do tell more of how you are getting heat with a water-cooled conversion. Here in New England, some of the nicest driving days are Spring & Fall when it can get a bit chilly after dark. Defog/defrost is the bigger issue, though. |
Lo-Fi Version | Time is now: 9th May 2024 - 08:04 AM |
