Removing broken bolt(s) from trailing arm mounts |
tazz9924 |
Apr 22 2018, 01:52 AM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
So I broke another bolt off in my rear right trailing arm pick up (the one behind the rocker panel) and i need suggestions for getting it out
914forme |
Apr 22 2018, 07:53 AM
Tangerine makes a replacement for the threaded insert section if you need it.
Tangerine - Trailing Arm Threaded Mounting Sleeve "The rear outer suspension consoles each have three of these. Our piece is an accurate repro of the factory component. This sleeve makes a quality repair possible if you are unable to repair the threads after breaking a bolt. A 7/8" hole saw will cut through the top weld on the console making it easy to remove the old sleeve." It is a backup to a problem that exists. Also there are plastic plugs at the top of these sleeves. You can add some penetrate. Take a punch and drop it in the top and top the top of the bolt. Rinse and repeat until your ready to give it a try. I have a set of reverse drill bits to give it a fitting chance. Best of luck with this repair. |
tazz9924 |
Apr 22 2018, 10:59 AM
Tangerine makes a replacement for the threaded insert section if you need it. Tangerine - Trailing Arm Threaded Mounting Sleeve "The rear outer suspension consoles each have three of these. Our piece is an accurate repro of the factory component. This sleeve makes a quality repair possible if you are unable to repair the threads after breaking a bolt. A 7/8" hole saw will cut through the top weld on the console making it easy to remove the old sleeve." It is a backup to a problem that exists. Also there are plastic plugs at the top of these sleeves. You can add some penetrate. Take a punch and drop it in the top and top the top of the bolt. Rinse and repeat until your ready to give it a try. I have a set of reverse drill bits to give it a fitting chance. Best of luck with this repair. I didn’t realize they were sleeved, thats good to know! Ill give it a try with some taps and a reverse drill bit or extractor and see what i can do |
Lo-Fi Version | Time is now: 17th May 2024 - 09:57 PM |
