Any experience with the AA forged crankshafts? |
stugray |
Apr 22 2018, 10:47 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I am looking for a good 2.0L stock crank (71mm).
It is for my race engine, so I would rather have forged than billet (like the SCAT product). Who has used a AA forged crank? Any issues? Do we know if these are brand new or reconditioned to be "new"? Anything to worry about or better options? https://aapistons.com/products/counterweigh...qxoCrTYQAvD_BwE |
zig-n-zag |
Apr 25 2018, 01:21 AM
Member Group: Members Posts: 182 Joined: 18-May 06 From: Hawaii Member No.: 6,024 |
A 66mm crank can be made into a 71mm crank by offset grinding the rod journals.
stugray |
Apr 25 2018, 01:44 PM
A 66mm crank can be made into a 71mm crank by offset grinding the rod journals. I was wondering if I could have a 1.8L crank ground down to a 2.0L crank. If the people doing the work can add a little weld to the outside of the journals you should be able to. I have TWO 1.8L cranks (paperweights) on my shelf. |
mgphoto |
Apr 25 2018, 03:30 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
A 66mm crank can be made into a 71mm crank by offset grinding the rod journals. I was wondering if I could have a 1.8L crank ground down to a 2.0L crank. If the people doing the work can add a little weld to the outside of the journals you should be able to. I have TWO 1.8L cranks (paperweights) on my shelf. 1.7 and 1.8 both 66 mm same crank. |
Lo-Fi Version | Time is now: 19th May 2024 - 07:51 AM |
