> 75 Fog Lamps - Installed
solex
post Apr 22 2018, 06:45 PM
Finally made the brackets and installed the stock fog lamps, but I blew two 16 amp fuse blows when I turn on the lamps.
I checked the lamps with a 12v battery out side the car and also checked to make sure that I had 12 volts into the fog lamp harness in the trunk everything checked out.
Is it possible that the bulbs are drawing too much current? Is it safe to measure the current at the fuse block w/o the fuse using a DVM?
Thanks,
Dan
914Sixer
post Apr 23 2018, 06:54 AM
Stock bulbs were 55 watts. Lights should be routed through relay on fuse plate.
jcd914
post Apr 23 2018, 08:55 AM
You would need to have some very high wattage bulbs for them to be blowing the fuse on their own.
Disconnect 1bulb and see if the fuse still blows. You can test fog light this way and see if one or the other is the problem.
Jim
Spoke
post Apr 23 2018, 11:28 AM
Jerry
QUOTE(solex @ Apr 22 2018, 08:45 PM) *
Thanks,
Dan
You can use the DVM if it has a 10A setting.
It was mentioned the bulbs are 55W.
Power is calculated as P = V x I. So current I = P/V = 55/12 ~ 4.5A each bulb.
Two bulbs would be 9A in steady state, maybe more on startup until the filaments heat up.
As mentioned, try one lamp and see if it pops the fuse. These do need a relay to protect the switch from damage.
solex
post Apr 24 2018, 06:36 PM
Thanks for the replies,
I disconnected one fog lamp and the fuse still blew. I tried a 25 amp fuse and had the same problem.
I have a set of H4's as my head lights I need to remove them to see what wattage they are perhaps the combination of the two is just too much
jcd914
post Apr 24 2018, 10:04 PM
QUOTE(solex @ Apr 24 2018, 05:36 PM) *
If you wired the fog lights like the factory did, the headlights and fog lights are on different fuses.
From the factory each low beam has a fuse and each high beam has a fuse and the fog lights are on another fuse. The fog lights also use a relay.
So 4 separate fuses for the headlights and 1 fuse for the fog lights.
Fuses 1 & 2 are the low beams
Fuses 3 & 4 are the high beams
Fuse 10 has the fog lights.and horn.
Jim
porschetub
post Apr 24 2018, 10:19 PM
QUOTE(jcd914 @ Apr 25 2018, 04:04 PM) *
Jim
Sounds like a dead short to ground (-),just saying.
BENBRO02
post Apr 25 2018, 05:19 PM
QUOTE(porschetub @ Apr 25 2018, 12:19 AM) *
Jim
I've got what appears to be the exact same problem in my 75. The lights come on but blow the fuse after a short amount of time or when the horn is honked. I suspect they were wired without a relay. I'm wondering if I can install some led bulbs instead of rewiring with a relay?
solex
post Jun 3 2018, 06:23 PM
dead short, was correct.
I should have guessed that it was a problem with my wiring, turns out that the female connector at the drivers side light bent and was grounding on the fog lamp housing.
I installed a new connector and installed heat shrink tubing on all four connectors.
This car has not had fog lamps for 43 years...
DRPHIL914
post Jun 3 2018, 07:11 PM
Dr. Phil
looks great! they will help a lot at night if you have stock headlights. the new LED's are nice too-- It looks like your left one need a slight adjustment, its looks as though it is pointed outward slightly. anyway I really like the yellow!
914Sixer
post Jun 3 2018, 07:12 PM
Looking good ! (IMG:style_emoticons/default/aktion035.gif)
ndfrigi
post Jun 3 2018, 09:21 PM
QUOTE(Philip W. @ Jun 3 2018, 06:11 PM) *
Dr. Phil, i think you are referring to the 2nd pic. That light on the floor seems to be coming from the sunlight and not from the foglamp. A little orange light maybe from the foglamp.
Ed_Turbo
post Jun 3 2018, 11:09 PM
Dan,
What studs did you go with for the Porsche black lug nuts? I am pretty much doing the same setup with my stock steelies.
Big Ed
solex
post Jun 4 2018, 07:54 AM
QUOTE(Ed_Turbo @ Jun 4 2018, 01:09 AM) *
Dan,
Big Ed
Thanks all for the positive comments, and the help. Fabricating the brackets was a bit of a pain but am very happy with the end result.
Ed, I'm using stock lugs with lug covers, I had them for some times so I do not know where they are source from.
rhodyguy
post Jun 4 2018, 08:54 AM
Most aftermarket VW vendors sell the black plastic lug covers. Total PITA to remove on the side of the road.
Ed_Turbo
post Jun 4 2018, 02:48 PM
Oh yeah I know what those are. They look like black lug nuts the Fuch’s guys use.
You need the tool to remove the caps.
-Big Ed
- Lo-Fi Version Time is now: 16th April 2024 - 04:13 PM
