FS 5 lug converted Rear Hubs with studs $265 Shipped, 3 pair as of 3/12/2019, with or with out cores |
flmont |
Oct 1 2018, 10:26 AM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
Yea,..I know the fronts cant be modded I would just keep the front stock,..I have 2 914's so Iam just bouncing around ideas , ???
flmont |
Oct 1 2018, 10:34 AM
True,..would you do it Bdstone914 if I decide to go that way ?? I just like that look,..I have 2 914's so Iam just kicking around ideas on how I want to set them up,.
bdstone914 |
Oct 1 2018, 11:59 AM
bdstone914 Group: Members Posts: 4,508 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
bdstone914 |
Mar 12 2019, 10:26 PM
Bump, Three more pairs as of 3/12/2019
Freezin 914 |
Mar 13 2019, 06:27 AM
Senior Member Group: Members Posts: 835 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest |
Hello, interested in these, question is, can I buy the front conversion parts separately from PMB? Is there any thing else needed to finish the rear conversion? Other than these hubs? Thank you.
bdstone914 |
Mar 14 2019, 08:17 AM
Hello, interested in these, question is, can I buy the front conversion parts separately from PMB? Is there any thing else needed to finish the rear conversion? Other than these hubs? Thank you. You will need rotors for the rear. You can have 4 lug rotors drilled to 5 lug. Or get 914-6 rotors and turn down the diameter 4mm. Ask Eric if he will sell the front conversion parts. Bruce @freezing914 |
Lo-Fi Version | Time is now: 19th April 2024 - 09:14 PM |
