Steering shaft boot/bushing and/or adjustment question, ...need some advice/direction |
naro914 |
May 6 2018, 12:51 PM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
For a long time, steering in Huey has been difficult - VERY hard to turn like something was always fighting you. I knew the boot that covers the shaft under the gas tank was never installed so I thought maybe the problem was that the tank was sitting on the shaft or bushings or something.
So today I took out the gas tank and sat looking at it. First....I have no clue how to put the boot on (do I have to drop the rack for that?) but I think the real problem is different. I undid the two allen bolts that hold the U bracket on and slid the rubber bushings out of the was to asses things. Immediately the shaft moved right up against the sides of the hole where it comes through the firewall and relieved the pressure it was under. (see picture) In other words, the shaft was NOT centered at all in that hole, so with the bushings trying to center the shaft, they were putting an immense amount of pressure on the shaft, thus making it hard to turn. (at least this is my theory). In fact, sometimes you can hear a squeaking/creaking type sound when turning the wheel, like metal moving tightly on rubber... I thought "ok, adjust the U-joints to allow the shaft to be centered". no dice since you can't lengthen/shorten the shaft in the U Joints because of the notch they have where the tightening bolt goes through. So....questions for the 914world brain trust: 1) how can I adjust things to get that shaft centered through the firewall hole? 2) how do I get the boot on? 3) where can I get new versions of all those bushings? there seems to be two (1 & 2 in my picture) and I guess a bearing (3)? thoughts? TIA |
iankarr |
May 10 2018, 03:21 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
I know that, on my car, I could get the rack out (and in) without dropping the aux support. Pulling it was a two man job. One person in the cabin prying the U joint apart to let the splined shaft slide out...while another is under the car pulling the rack down (yanking, really). MAKE SURE THE CAR IS VERY STABLE!
EDIT: I deleted what I wrote here about dropping the support being easy, as I was having a brain fart. |
naro914 |
May 10 2018, 03:58 PM
I know that, on my car, I could get the rack out without dropping the aux support. It was a two man job. One person in the cabin prying the U joint apart to let the splined shaft slide out...while another is under the car pulling down (yanking, really). MAKE SURE THE CAR IS VERY STABLE! That said, dropping the aux support is a 5 minute thing...just 4 bolts. And it should have no effect on alignment or steering geometry. Might give you the wiggle room you need. Certainly couldn't hurt. 4 bolts? I took out the big 19mm ones near the torsion bar “hinge” , and even th 4 up at the control arms up front. Support won’t budge....which I can’t understand since nothing is holding it in except at the bottom of the strut....hmm....and the sway bars....hmmmm |
iankarr |
May 10 2018, 04:05 PM
I know that, on my car, I could get the rack out without dropping the aux support. It was a two man job. One person in the cabin prying the U joint apart to let the splined shaft slide out...while another is under the car pulling down (yanking, really). MAKE SURE THE CAR IS VERY STABLE! That said, dropping the aux support is a 5 minute thing...just 4 bolts. And it should have no effect on alignment or steering geometry. Might give you the wiggle room you need. Certainly couldn't hurt. 4 bolts? I took out the big 19mm ones near the torsion bar “hinge” , and even th 4 up at the control arms up front. Support won’t budge....which I can’t understand since nothing is holding it in except at the bottom of the strut....hmm....and the sway bars....hmmmm Sorry...I was having a brain fart when I wrote that. The A arms are tied in by the bracket at the front, the sway bar and the ball joint. I hope I don't have early onset carzheimers. |
Lo-Fi Version | Time is now: 28th May 2024 - 04:37 PM |
