WTB: Taco plate and taco plate cover for oil temp sender |
Mr Beckstar |
May 7 2018, 06:36 AM
Newbie Group: Members Posts: 25 Joined: 28-April 18 From: Australia Member No.: 22,082 Region Association: Australia and New Zealand |
G’day from down under. My first post on here and I’m trying to do the right thing but it’s a bit different so not sure if I’m stuffing it up. I’m sure someone will let me know though :-)
I’m looking far and wide for the taco plate that accommodates the oil temperature sensor in the sump of the 2L engine. And also the associated parts such as the cover and perhaps the crush washers if you’ve got new ones of those. I’m not so worried about the sensor itself. Are there any out there in good condition? |
rhodyguy |
May 22 2018, 12:49 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
perhaps I could interest you in this package. base, sender, cover piece and the elusive factory wire. clean parts, NOT needing a bunch of rust to contend with. you may run the wire as the factory intended. behind the fan shroud. a new gasket will be required.
you'll need to note the portion of my signature that's in red caps. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 05:57 PM |
