WTB: Taco plate and taco plate cover for oil temp sender |
Mr Beckstar |
May 7 2018, 06:36 AM
Newbie Group: Members Posts: 25 Joined: 28-April 18 From: Australia Member No.: 22,082 Region Association: Australia and New Zealand |
G’day from down under. My first post on here and I’m trying to do the right thing but it’s a bit different so not sure if I’m stuffing it up. I’m sure someone will let me know though :-)
I’m looking far and wide for the taco plate that accommodates the oil temperature sensor in the sump of the 2L engine. And also the associated parts such as the cover and perhaps the crush washers if you’ve got new ones of those. I’m not so worried about the sensor itself. Are there any out there in good condition? |
rhodyguy |
Jun 5 2018, 07:35 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Pleased I could be of help. You'll have to pull the fan shroud to access the studs to run the wire 'factory style'.
Mr Beckstar |
Jun 5 2018, 08:43 PM
Pleased I could be of help. You'll have to pull the fan shroud to access the studs to run the wire 'factory style'. Yes, I’ve got a couple of other reasons to do that too. One is that one of the small gravity controlled lower flaps on the fan housing that feeds to the heater box is not working properly. |
Lo-Fi Version | Time is now: 17th May 2024 - 07:11 PM |
