WTB: Taco plate and taco plate cover for oil temp sender |
tweet |
May 22 2018, 01:40 PM
Member Group: Members Posts: 200 Joined: 25-February 13 From: South Florida Member No.: 15,579 Region Association: South East States |
Wow, the whole assembly. A rare find these days. Trustworthy seller. |
Mr Beckstar |
May 22 2018, 08:00 PM
Newbie Group: Members Posts: 25 Joined: 28-April 18 From: Australia Member No.: 22,082 Region Association: Australia and New Zealand |
perhaps I could interest you in this package. base, sender, cover piece and the elusive factory wire. clean parts, NOT needing a bunch of rust to contend with. you may run the wire as the factory intended. behind the fan shroud. a new gasket will be required. you'll need to note the portion of my signature that's in red caps. Yes, signature in red caps noted. I'm interested. I'll send a PM |
rhodyguy |
May 23 2018, 07:23 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
PM sent Chris.
Mr Beckstar |
Jun 5 2018, 06:06 AM
PM sent Chris. Received the taco plate and cover today. Thanks Kevin, I’m a very happy camper and so is Harry (IMG:style_emoticons/default/biggrin.gif) |
rhodyguy |
Jun 5 2018, 07:35 AM
Pleased I could be of help. You'll have to pull the fan shroud to access the studs to run the wire 'factory style'.
Mr Beckstar |
Jun 5 2018, 08:43 PM
Pleased I could be of help. You'll have to pull the fan shroud to access the studs to run the wire 'factory style'. Yes, I’ve got a couple of other reasons to do that too. One is that one of the small gravity controlled lower flaps on the fan housing that feeds to the heater box is not working properly. |
Lo-Fi Version | Time is now: 24th April 2024 - 03:03 PM |
