2056 build compression ratio dilema |
jjs3rd914 |
May 8 2018, 08:44 AM
Member Group: Members Posts: 124 Joined: 8-August 04 From: Sarasota, FL Member No.: 2,476 |
Building a 2056, want good low end torque and drivability. Car has AC. Targeting 115-125 HP
GA 2L case, stock 2L crank rods, new AA 96mm pistons, biral cylinders New AA 2L heads with 44/36 valves Webcam 086 cam Weber 40IDF dual carbs After numerous searches seem like 8.5 is optimal compression ratio (CR) and the build should get me the targeted HP. BUT finding during assembly, with a deck height of .065" (with .010 barrel spacer) 60 cc head volume which includes 2CC for the piston valve recess, I am only getting 8.1. So option are to leave alone and go with 8.1CR or Machine heads to loose about 6CC or machine barrels to reduce deck height. Was told must use a barrel spacer and am using the thinnest I can find at .010. To get the targetd HP do I need to get to a CR of 8.5, or will 8.1 get me there.? Am really confused about the whole CR optimal number for what I want. Thanks jjs3rd914 |
nditiz1 |
May 8 2018, 09:27 AM
Senior Member Group: Members Posts: 1,180 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
I was running into the same issue. I'm not sure about the barrel spacers, but I had to have .5mm taken off the bottom of the jugs. Ideally I wanted to have .90 10mm of DH, but my initial measurement was off by .1mm. This got me a final DH of 1mm which is 8.4 CR. I have pretty much the same exact setup you have. Im running no spacers or gaskets from block to head.
Lo-Fi Version | Time is now: 4th May 2024 - 01:22 PM |
