2056 build compression ratio dilema |
jjs3rd914 |
May 8 2018, 08:44 AM
Member Group: Members Posts: 124 Joined: 8-August 04 From: Sarasota, FL Member No.: 2,476 |
Building a 2056, want good low end torque and drivability. Car has AC. Targeting 115-125 HP
GA 2L case, stock 2L crank rods, new AA 96mm pistons, biral cylinders New AA 2L heads with 44/36 valves Webcam 086 cam Weber 40IDF dual carbs After numerous searches seem like 8.5 is optimal compression ratio (CR) and the build should get me the targeted HP. BUT finding during assembly, with a deck height of .065" (with .010 barrel spacer) 60 cc head volume which includes 2CC for the piston valve recess, I am only getting 8.1. So option are to leave alone and go with 8.1CR or Machine heads to loose about 6CC or machine barrels to reduce deck height. Was told must use a barrel spacer and am using the thinnest I can find at .010. To get the targetd HP do I need to get to a CR of 8.5, or will 8.1 get me there.? Am really confused about the whole CR optimal number for what I want. Thanks jjs3rd914 |
Jake Raby |
Jan 18 2021, 11:52 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
This is where a mock up of components up front comes into play.
The deck height can be altered best by cutting the case registers to reduce deck height. I am finding 100% of T4 crankcases these days needing the decks cut to flatten them. The worst of these are the GA and GC 914 2.0 cases. I am seeing .020" needing to be cut to flatten all the surfaces. This is due mostly to casting age, and not mileage. If your cylinders measure 3.600" from case deck, the the head selfing surface, you'll have a better chance of having things install with more reasonable deck height figures to attain a CR of 8.5:1 or higher, based on the engine combo. |
Lo-Fi Version | Time is now: 25th April 2024 - 12:11 AM |
