Boxster axles |
Boxster axles |
partwerks |
May 10 2018, 01:24 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
From what I understood the 5 speed Boxster trans, the axles were two different lengths. At the start he said the axles fit, I thought something didn't seem right, but now that we finally got to doing the wheel alignment, I was correct in that the passenger side is too short. He said about 1/2".
Does anyone know what the correct length of axle would be on the passenger side using the 5 speed Boxster trans, and if so, where I can acquire one at? |
burton73 |
May 10 2018, 02:04 PM
burton73 Group: Members Posts: 3,498 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Renegrade in Las Vegas does these with V8s call them and ask.
Bob B |
Chris914n6 |
May 10 2018, 03:22 PM
Jackstands are my life. Group: Members Posts: 3,304 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Mark Henry |
May 10 2018, 04:13 PM
Try Sway a Way
https://swayaway.com/product-category/axles/ Worst case they will make custom axles for you. |
krazykonrad |
May 10 2018, 06:30 PM
Senior Member Group: Members Posts: 1,124 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
(IMG:style_emoticons/default/pirate.gif)
Not to hijack your thread, but I played football at Hastings College right down the road from you. Konrad |
partwerks |
May 10 2018, 07:50 PM
(IMG:style_emoticons/default/pirate.gif) Not to hijack your thread, but I played football at Hastings College right down the road from you. Konrad I did a lot of blood drives over at that college also. |
Andyrew |
May 11 2018, 09:35 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Are you using the boxster trans on the 914? Sorry I think I miss read your post first time. Mike bellis had a 5 speed boxster/Passat unit in the car before he put the 6 speed. Check his build thread for measurements.
I have one in my car but I removed the trans mounts and moved them as they are offset in a 914 and it was also in the way of the shifter assembly. I have equal length axles and use an off the shelf vw Bus axle like rennegade hybrid uses on their 500hp axle solution. |
partwerks |
May 22 2018, 05:08 PM
Is anyone else using the 5 speed boxster trans with the LS3 engine that could advise me on the axle lengths?
yellowporky |
May 22 2018, 10:23 PM
Member Group: Members Posts: 422 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California |
I have a boxster 5 speed in one of my cars and as far as i recall the reason for the different lengths was because of an offset in the trans and has nothing to do with the type of engine. my rear suspension is not 914 so i have no idea if the boxster axels and trans would work with the 914 suspension or as others have mentioned you might need custom axels or spacers.
Good luck. |
Chris914n6 |
May 22 2018, 11:19 PM
Is anyone else using the 5 speed boxster trans with the LS3 engine that could advise me on the axle lengths? An LS3 will destroy a Boxster/VW/Audi 5 speed. All the adapters I've seen have been to the 6 speed as it's more than twice as beefy. The 5 speed is only a little bit stronger than a built 914 box. |
Andyrew |
May 23 2018, 10:01 AM
Is anyone else using the 5 speed boxster trans with the LS3 engine that could advise me on the axle lengths? An LS3 will destroy a Boxster/VW/Audi 5 speed. All the adapters I've seen have been to the 6 speed as it's more than twice as beefy. The 5 speed is only a little bit stronger than a built 914 box. Exactly.. The only way Im getting away with the 5spd box on my car is with how large my turbo is the initial impact to the trans is much lower, regardless of my actual HP.. I wouldnt put anything more than a 5.3 in front of the 5spd, even then I wouldnt expect it to last very long. A 4.8 would be a decent match. |
Andyrew |
May 23 2018, 10:04 AM
I have a boxster 5 speed in one of my cars and as far as i recall the reason for the different lengths was because of an offset in the trans and has nothing to do with the type of engine. my rear suspension is not 914 so i have no idea if the boxster axels and trans would work with the 914 suspension or as others have mentioned you might need custom axels or spacers. Good luck. Correct. When I mounted my setup I equally spaced the trans so the axles would be the same length, this allowed me to run off the shelf axles. Location of the axles placed the whole engine setup for me. I did so to avoid the issues Bellis ran into with the popping out of the axles. |
JRust |
May 23 2018, 10:17 AM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I think the consensus is you better get the 6 speed Lyle. I would try to get with Mike Bellis to make sure you get the right stuff. He's got it down pat
partwerks |
May 24 2018, 07:23 PM
If I decided to go that route, where would be a good place to get the 6 speed, and everything I would need to complete the setup?
Mike Bellis |
May 25 2018, 06:59 AM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
My setup is totally custom. I run 930CV's with both my 6 and 5 speed. My 5 speed has custom 108mm stubs. I use the same axles on both with the addition of a 7/16 CV spacer that doubles at the magnetic speedo pickup.
I purchased multiple axle lengths until I found the sweet spot. I run non-plunging CV's. This requires me to run sliding axles. (normal CV are plunging with fixed axles). I fine tuned my setup to work with either tranny. I spoke to Lyle and I'm not convinced that his mechanic have the skills to complete this build. I base this on some of the basic component setup confusion on his part. If there is an "easy" way... Make your build use the same size CV for both the inner and outer. Then buy the correct length axles. They will be about 3/4"-1" different in length. Remove the rear wheel and disconnect the shock. This will allow you to easily raise and lower the suspension until you find the closest distance between the tranny and wheel hub. Take this shortest measurement and subtract 1/2" this is your maximum axle length. Then buy axles with a spline count that matches your CV's. If you have 100mm CV's, you spline count most likely is 33. If you run 108mm CV's you spline count is 28. If both CV's match, axles can be purchased off the shelf. If you need 33 on one side and 28 on the other, this requires a custom machined axle. If you have a 5 speed, this is 100mm. If you have a 6 speed, this is 108mm. |
Mike Bellis |
May 25 2018, 05:52 PM
If you do 6 speed, it will have 108mm stubs. You can buy 108mm wheel stubs from an early 911 and run 930 CV's. This would be the easiest way to complete the axle build. The cost is a 6 speed tranny.
Lo-Fi Version | Time is now: 26th April 2024 - 10:28 AM |
