Boxster axles |
Boxster axles |
partwerks |
May 10 2018, 01:24 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
From what I understood the 5 speed Boxster trans, the axles were two different lengths. At the start he said the axles fit, I thought something didn't seem right, but now that we finally got to doing the wheel alignment, I was correct in that the passenger side is too short. He said about 1/2".
Does anyone know what the correct length of axle would be on the passenger side using the 5 speed Boxster trans, and if so, where I can acquire one at? |
Andyrew |
May 11 2018, 09:35 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Are you using the boxster trans on the 914? Sorry I think I miss read your post first time. Mike bellis had a 5 speed boxster/Passat unit in the car before he put the 6 speed. Check his build thread for measurements.
I have one in my car but I removed the trans mounts and moved them as they are offset in a 914 and it was also in the way of the shifter assembly. I have equal length axles and use an off the shelf vw Bus axle like rennegade hybrid uses on their 500hp axle solution. |
Lo-Fi Version | Time is now: 8th May 2024 - 07:37 PM |
