Engine kit, most everything but the rotating parts |
JimN73 |
May 13 2018, 10:58 AM
Senior Member Group: Members Posts: 535 Joined: 6-October 07 From: Gig Harbor Member No.: 8,192 Region Association: Pacific Northwest |
Price: $500 plus shipping
First: An early1.7 liter engine that I tore down a couple of years ago and don't expect to build. I didn't take pictures of everything - if you've seen one windage tray, you've seen them all. Here's what you get. Case halves, line bored with main bearings to match - standard crank. New studded case bolts Oil galleys have been removed and threaded for inserts - aircraft quality inserts included. Pushrods, tubes and lifters. Maybe original/ Oil cooler and bracket Dipstick, oil filler and components. Windage tray with gaskets. Both oil pressure relief springs and pistons Oil pump. Maybe original. Taco plate Cam gear, distributor bracket, and related parts Valve covers Fan Fasteners. Second: Set of 2 liter heads with no visible cracks. Valves, springs and related parts 1.7 liter rockers with all related parts I have some tin, not the top parts. Not included but yours for the freight [attachmentid=650 749][attachmentid =650754] Attached image(s) |
rhodyguy |
May 13 2018, 11:48 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,061 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Pretty sweet deal using these components for your new engine assembly. the heads and rockers are prob worth more than 1/2 the asking. Jensco reliant(sp?) did the case work. Remember, you'll only pay shipping one way. Not x2 from points unknown and return. GLWTS Jim.
Lo-Fi Version | Time is now: 27th April 2024 - 08:14 AM |
