WTB:SHIFT ROD END FITTING, with brass insert ? |
Wayne |
May 14 2018, 01:49 PM
SoCal-Bumblebee Group: Members Posts: 47 Joined: 29-January 16 From: Orange County, CA Member No.: 19,612 Region Association: Southern California |
euro911 |
May 14 2018, 03:33 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
It looks like a bronze cup bushing insert instead of a plastic cup bushing? Look deep inside to see if it's hemispherical at the bottom.
Wayne |
May 14 2018, 05:25 PM
Mark
It's not a cup insert. It's shaped like a Conduit Coupling and is hollow all the way through. When we put it on the ball shifter it's a little loose so not sure that's an ok fit ? |
euro911 |
May 14 2018, 06:42 PM
OK, Wayne. Will the sleeve come out? It looks like it should, then a plastic cup bushing can be installed in it's place. The bushing is available from multiple vendors, including Pelican Parts down here in Harbor City ... https://www.pelicanparts.com/catalog/SuperC...T_pg2.htm#item4
Are you replacing any other shift bushings? ... they have all of those as well ... https://www.pelicanparts.com/catalog/SuperC...T_pg2.htm#item4 |
Wayne |
May 14 2018, 09:04 PM
Mark
I do have all new bushings including a new ball cup bushing. I’m wondering why I couldn’t just use what I have if it’s a bronze insert ? Give me call if you have time tomorrow 909-208-3184 Thanks |
euro911 |
May 14 2018, 10:52 PM
If it IS an bronze insert, look to see if it has a hemispherical shape milled at the bottom.
Also, not that they may not exist, but I've never seen a cup bushing that sits level with the outer edge of shift coupling ... usually the plastic ones are sunken in to a certain depth. I wonder if the length of that insert would limit the travel of the shaft (IMG:style_emoticons/default/confused24.gif) |
rgalla9146 |
May 15 2018, 05:00 PM
Advanced Member Group: Members Posts: 4,538 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Is there a source for a brass or bronze replacement ? |
screenguy914 |
May 15 2018, 05:57 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
I'm going to guess the insert doesn't bottom out to allow space for free movement of the ball end. Otherwise, you have in effect a rigid 90º joint - something has to give in the fore/aft lever motion. AFAIK, your other plastic/nylon shift bushings may be distorting to compensate for that rigid joint.
The slop you feel is the planned space between the lever and that metal bushing. Suggest removing the bushing and install the factory nylon ball socket to reduce the excessive play. Sherwood |
914Sixer |
May 16 2018, 05:42 AM
914 Guru Group: Members Posts: 8,845 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Never seen a brass insert. Thinking it is a custom made piece.
brant |
May 16 2018, 09:59 AM
914 Wizard Group: Members Posts: 11,584 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I've never seen a metal insert for this bushing either.
not sure how well it would work? the original bushing design is very adequate they do not wear out (although I replace them anyways due to plastic only lasting so long) the original design of this joint has one flaw, but its not in the bushing wear at full range of motion, the bushing pulls out about halfway from the cup and the bottom half of the bushing is unsupported. I run a modified cup in my race car to improve this situation. A ring is welded onto the cup making it a deeper fit. The ring is then machined smooth internally on a lathe. Additionally the two (180 degree apart) edges of the cup are notched to allow full range of motion by the linkage at full extension. probably have a picture in my thread somewhere. my guess is that your part looks to have been recently plated someone put that hollow insert into the cup to keep the plating off of the inside surfaces of the cup where the bushing needs a smooth face. I'm guessing the plating on the outer lip has bonded that insert into that cup. break the bond and it will likely slide out. b |
sbartmess |
May 16 2018, 01:49 PM
Newbie Group: Members Posts: 9 Joined: 28-July 17 From: Chicago Member No.: 21,295 Region Association: Upper MidWest |
To remove stubborn bushings, I put the coupler in my chest freezer over night. The bushing shrinks concentrically, and comes out with one tap.
Lo-Fi Version | Time is now: 29th March 2024 - 02:25 AM |
