Glass polishing, Any tips? |
bbrock |
May 15 2018, 09:12 AM
The last thread I found on this topic is almost 10 years old so thought it would be worth revisiting. I bought a set of tinted side glass that looks pretty good but has a patina of minor pits, scratches and scale you might expect from 50 year old glass. They'll need to be polished before I can use them. Anyone done this or have any suggestions or tips? There are lots of YouTube videos and other sources that make it look easy, but it's always nice to get help from people you trust and aren't trying to sell you something.
Thanks (IMG:style_emoticons/default/beer.gif) |
djway |
May 16 2018, 04:57 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
Cerium oxide to polish out fine scratches. Deep scratches can be done, I have done it, and it is a TON of work.
I did an early Ghia that had very bad scratches everywhere. I tried all sorts of materials, some made things worse but I did find a working solution. 6 inch pad with wet/dry paper, the starting grit depending on how deep the scratch is. You must have water running over the glass at all times to keep the temp down. As with anything you keep going to finer and finer grits and then you finish off with the cerium oxide. You must pull the glass and set up a table with the set water supply. It is a lot of work. My Ghia glass is very rare and expensive so it was worth the hundreds hours invested. Good luck |
Lo-Fi Version | Time is now: 24th April 2024 - 04:14 AM |
