Subaru EZ30R conversion, will the 6 speed transmission work? |
Aircooledfool |
May 15 2018, 12:18 PM
Member Group: Members Posts: 106 Joined: 17-September 06 From: Texas Member No.: 6,858 Region Association: None |
I would like to use the 6 speed transmission that I can purchased mated to the EZ30R. When I look at Bremarauto's site, they say their 2WD conversion kit does not work with the 6 speed. Has anyone already used this transmission? If so, can you point me to the conversion parts you used?
Chi-town |
Sep 5 2018, 07:06 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
No real benefit to the 6 speed as first and last gear are the same ratio as the 5 speed. In my opinion, it's mostly negative from a 914 perspective. If you plan to really beat on it the 5mt will shatter 2nd or 3rd under heavy launches with stock gears. They also have a known issue where the 3rd gear double coned syncro with break the double cone causing shifting issues into 3rd and 4th. The JDM RA boxes and USDM LGT boxes will hold up to a bit more but nothing close to the 6MT. |
Chris914n6 |
Sep 5 2018, 07:57 PM
Jackstands are my life. Group: Members Posts: 3,310 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
No real benefit to the 6 speed as first and last gear are the same ratio as the 5 speed. In my opinion, it's mostly negative from a 914 perspective. If you plan to really beat on it the 5mt will shatter 2nd or 3rd under heavy launches with stock gears. They also have a known issue where the 3rd gear double coned syncro with break the double cone causing shifting issues into 3rd and 4th. The JDM RA boxes and USDM LGT boxes will hold up to a bit more but nothing close to the 6MT. Is that in a 3400lb awd car or a 2200lb 914? Thanks to physics the results will vary... |
Lo-Fi Version | Time is now: 4th May 2024 - 03:03 AM |
