Programmable distributor alternative to the 123Ignition units?, 2016 Maganspark from CB Performance |
Mueller |
May 15 2018, 02:47 PM
Just pulled the plug and bought this kit yesterday.
4 preset curves via dip switches. Don't like those and you can use your laptop to make custom curves and a 3D map. I didn't get in on the 123Ignition group buy and stumbled upon this setup. As a plus it comes with wires and a new coil and can be used with boost. $360. I'm using L-Jet for fuel and it'll fire the injectors when the coil collapses just like a stock distributor. https://www.cbperformance.com/product-p/2016.htm |
porschetub |
May 15 2018, 03:06 PM
Advanced Member Group: Members Posts: 4,695 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Nice to see another option out there,will the unit clear the engine tin on a T4?,how do the vacuum pickups work? I see 4 of them?.
Should be a good unit,good luck with it. |
Lo-Fi Version | Time is now: 29th March 2024 - 08:02 AM |
