Programmable distributor alternative to the 123Ignition units?, 2016 Maganspark from CB Performance |
Mueller |
May 15 2018, 02:47 PM
Just pulled the plug and bought this kit yesterday.
4 preset curves via dip switches. Don't like those and you can use your laptop to make custom curves and a 3D map. I didn't get in on the 123Ignition group buy and stumbled upon this setup. As a plus it comes with wires and a new coil and can be used with boost. $360. I'm using L-Jet for fuel and it'll fire the injectors when the coil collapses just like a stock distributor. https://www.cbperformance.com/product-p/2016.htm |
Amphicar770 |
May 15 2018, 04:50 PM
Senior Member Group: Members Posts: 1,181 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
This on their web site. ...
NOTE: MAGNASPARK II & MAGNASPARK Digital will not fit T-3 or T-4, without modification the engine tin. Resistor spark plugs are required. Bosch Blue Coils are NOT compatible. Resistor spark plugs are required |
Mueller |
May 15 2018, 05:23 PM
This on their web site. ... NOTE: MAGNASPARK II & MAGNASPARK Digital will not fit T-3 or T-4, without modification the engine tin. Resistor spark plugs are required. Bosch Blue Coils are NOT compatible. Resistor spark plugs are required About same mods as if installing a Mallory or MSD distributor, no big deal. |
michael7810 |
May 16 2018, 12:27 PM
Senior Member Group: Members Posts: 1,078 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
This on their web site. ... NOTE: MAGNASPARK II & MAGNASPARK Digital will not fit T-3 or T-4, without modification the engine tin. Resistor spark plugs are required. Bosch Blue Coils are NOT compatible. Resistor spark plugs are required About same mods as if installing a Mallory or MSD distributor, no big deal. Can you post a pic of the tin mod? This looks interesting... |
Lo-Fi Version | Time is now: 29th March 2024 - 07:35 AM |
