MPS function, still tuning after these years |
worn |
May 16 2018, 10:23 AM
can't remember Group: Members Posts: 3,147 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I have read and re-read PB Anders' epic work. Bought a Henry meter and everything , but there is one thing I am puzzled by. It looks like from idle to part throttle the pulse length is controlled by the contraction of the aneroid bellow. This produces a pretty straight vacuum- inductance slope. Which means that if you set one end of the curve for A/F ratio, say at idle, or part throttle, all of the other points on the line are fixed, based on the bellows and the spring rate. If you move a line with constant slope all of the points move by the same amount.
Nonetheless, there is some talk about setting mid throttle as though it can be adjusted independent of closed throttle. The reason I am asking is I have been chasing a partial throttle dead spot in the 2,000-3,000 rpm range under partial load. Idle is too rich (11-12) and at the dead spot the mixture goes way lean (16-17 or higher). I can move the diaphragm stop (outer screw), but that doesn't change the range or slope of the aneroid, it seems to be mostly involved with WOT control (which works fine for me). So I cannot understand how that could affect partial throttle ranges. Is there a way of adjusting mid-throttle independently from closed throttle? I should add that it is a 2056 with 8.5 static compression and a Web cam 73 with so called Raby grind (can't blame Jake here, I ordered it without his help). I rather think it would work better as stock. But, I get really close. |
McMark |
May 16 2018, 10:51 AM
You have three basic conditions:
1. Vacuum is high. The internal canisters are expanded and the armature is limited by the outer diaphragm screw. This is your idle mixture. 2. Vacuum is low. The internal canisters are... compressed isn't the right word... neutral? and the armature is limited in the opposite direction by the nose stop screw (the one with epoxy on it). This is your full throttle mixture. 3. In between the stop screws aren't touching anything, and the varying expansion of the canisters controls mixture. You can adjust the fuel ratio in this zone by adjusting the center diaphragm screw. This is your part load -- everything in between idle and full throttle. If you lack idle vacuum, the outer diaphragm screw isn't pulled against the stop. And if it's not pulled against the stop, you're missing part of the adjustment. You need more vacuum to get to the 'idle zone'. In this case you may have to compromise your idle mixture to get your part-load mixture correct. |
Lo-Fi Version | Time is now: 26th April 2024 - 02:58 PM |
