Gas Gauge Inaccurate |
stevend914 |
May 16 2018, 04:55 PM
Member Group: Members Posts: 376 Joined: 13-December 16 From: Saint Louis Member No.: 20,670 Region Association: Upper MidWest |
On my trip back from Corpus Christi my gas gauge is not indicating correctly, shows 1/2 or 1/4 full after I've filled the tank...but the reserve light is operating correctly. I'm sure there's a thread on this but my search worked as well as my gas gauge
r_towle |
May 16 2018, 05:08 PM
Custom Member Group: Members Posts: 24,573 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
well, could be a few things.
All require you to remove the expansion tank, and then the fuel level sending unit in the top of the tank (lots of little bolts) Could be: 1) sender electronics are bad (check with a multimeter) 2) float is cracked (get a new sender) 3) rod that float is on is crusty and float is stuck (clean everything) Test is if the float is bad by making sure there is no fluid iin it, and submerse it in water, look for bubbles. Rich |
Lo-Fi Version | Time is now: 5th May 2024 - 01:08 PM |
