turbo tie rod install driver side inner spring |
Geezer914 |
May 16 2018, 06:41 PM
Geezer914 Group: Members Posts: 1,383 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Installed a set of turbo tie rods today. Installing the inner spring on the passenger side boot was not bad. The driver side is another story. There is hardly any room with the master cylinder and brake lines in the way. I have it about 3/4's of the way on, but can't reach the top. Short stubby fingers don't help. Any tips? (IMG:style_emoticons/default/hissyfit.gif)
iankarr |
May 16 2018, 06:48 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,471 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Try a long (thin) allen key in a vice grip. The 90 degree part should allow you to slip under the spring and push it into place. A stiff coat hanger could also work.
Mark Henry |
May 17 2018, 06:55 AM
I have a couple bent up old screwdrivers that I used for the job. Just make sure it has no sharp edges that could cut the boot.
Once you get it on the backside you have it beat. |
Lo-Fi Version | Time is now: 25th April 2024 - 04:03 PM |
