Low Compression, running rough, backfire, Technical help please |
Don911 |
May 17 2018, 01:59 PM
Newbie Group: Members Posts: 17 Joined: 30-March 18 From: Charleston Member No.: 22,007 Region Association: South East States |
So I have searched the forum (and internet) before posting...sorry if this a tired old topic.
Trying to narrow down the cause for some backfiring through the carbs and rough running. Compression: #1-125, #2-90, #3-70, #4-85 Some oil around the air filter housing. #3 plug fouled so all were replaced. Carbs synched Valve job completed. Still: runs rough in lower RPM ranges especially when starting out and now I'm getting an occasional backfire through the carbs under acceleration. Mech says it caused by low compression and needs at least a top end rebuild. A lot of what I'm reading points toward...well a lot of things, but nobody says low compression causes the chugging from start and the backfire. Agree? Disagree? Not enough info? Thoughts please...thanks! |
tazz9924 |
Dec 12 2018, 07:26 PM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
So I have searched the forum (and internet) before posting...sorry if this a tired old topic. Trying to narrow down the cause for some backfiring through the carbs and rough running. Compression: #1-125, #2-90, #3-70, #4-85 Some oil around the air filter housing. #3 plug fouled so all were replaced. Carbs synched Valve job completed. Still: runs rough in lower RPM ranges especially when starting out and now I'm getting an occasional backfire through the carbs under acceleration. Mech says it caused by low compression and needs at least a top end rebuild. A lot of what I'm reading points toward...well a lot of things, but nobody says low compression causes the chugging from start and the backfire. Agree? Disagree? Not enough info? Thoughts please...thanks! Do a leak down test it will tell you exactly where the compression is being lost |
Lo-Fi Version | Time is now: 14th May 2024 - 01:17 AM |
