It shouldn't be this hard!, New fuel lines |
Jamie |
May 17 2018, 07:12 PM
Senior Member Group: Members Posts: 1,033 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
I moved the fuel pump to the front of my 73 1.7L FI several years ago, and last fall began the process of replacing all the remaining original fuel lines, especially the plastic lines in the tunnel. Since the tank had to come out it was time to have it cleaned and sealed, and "while I was at it" to gather parts and install an original front sway bar. So the tank was processed about 8 months ago, and on recent reinstall I discovered the original expansion tank mounts had disappeared. I did some Afro-engineering to make new mounts, got the tank installed, which became a monumental job! New filters and associated tubing in place, poured about a gallon of gas into the tank, and started a steady stream of fuel flowing out on the shop floor. Now my shop and lift are in the basement of my home, and I have to do most fuel related work with the garage doors open to avoid filling the house with gas fumes. The leak was at the main line coming out of the bottom of the tank, no way to fit hands or tools through the small round hole below, so the tank and all related parts, had to come completely back out. Dangit!!! (IMG:style_emoticons/default/headbang.gif) And those 2 black rubber chocks that hold the tank in position are a bi**ch to keep in place!! Resealed the outlet line that had a pinched fiber washer, and tested it for any leaks before reinstalling this time. Having to handle a tank with some fuel sloshing around, plugging all the disconnected fuel lines to avoid leaks, and manipulating the tank back in took most of the day. So finally all the hoses and clamps were connected and clamps checked, another gallon of gas poured into the tank, and I'm ready to start the engine for the final leak test both front and in the engine compartment. (IMG:style_emoticons/default/rolleyes.gif) Oh happy day!! (IMG:style_emoticons/default/w00t.gif) I turn the key, and no sound from the pump starting as usual? Now what, the pump wasn't disturbed in this whole process, other than the new fuel lines attached? And there doesn't seem to be much fuel coming through the new inline filter placed before the pump? So tomorrow I'll start troubleshooting the whole installation, is there power to the pump, or has the pump failed? I didn't expect it to be this difficult!!! (IMG:style_emoticons/default/barf.gif)
North Coast Jim |
May 19 2018, 11:19 AM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Had somewhat the same issues early last year getting our car back together. Tank was already out when I got the car. Had it cleaned and resealed from the inside. Moved the fuel pump, now a carb'd car, to under the steering rack and gravel pan. New filter sock and new fiber gaskets on both lines. Blocked the small line. Tank installed and all new fuel lines installed, including new Tangerine SS lines in the tunnel. Put in a gallon of gas and started car. Ran of course like crap as jetting was off. Left car in the garage for the night. Next morning smelled gas and pushed car outside. Drained gas and removed the tank. The small outlet had a pin hole rust through and weeped gas. Cut it short and reinstalled the shunted outlet line. This time I left the tank out of the car and put it up on saw horses. Put in some gas and left it for a couple of hours. Gas still weeping but this time on the large outlet fiber washer. The work went on and I'll not bore you with the details of needding new aluminum fasteners and chasing threads on the outlet of the tank, etc. What I can say is all this work was worth it. The car runs great now and (most) all items are now fixed. Car runs superbly. What a hoot to drive around. Stay the course. Treat it like an AA member, take it one day at a time. The reward is so much FUN with capital letters.
By the way if you moved the fuel pump forward you may have dislodged the wiring during tank removal/install and caused a disconnect at the pump. Ask me how I know. |
Lo-Fi Version | Time is now: 26th May 2024 - 01:46 PM |
