Slightly tailhappy... |
falcor75 |
May 18 2018, 01:15 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
I need to learn a bit of how to setup my car better.
Its got new Bilstein shocks all around, new bushings everywhere. Front has the stock torsion bars and a Tarret adjustable swaybar. Rear has 140lbs Weltmeister springs. Last year I ran it with no rear swaybar and the front swaybar set at about 25% from the outer most position. This got the car quite tailhappy when doing autocross/slalom events. During the Winter I added the stock rear swaybar just to see what difference it made and it calmed the tailhappyness down a bit but still a bit twitchy. Whats the next step? Decreaseing the front swaybar setting? Last year in the wet.. https://www.youtube.com/watch?v=yrh878om6pI This years first event https://www.youtube.com/watch?v=Eer4JyMl_PI |
ConeDodger |
May 21 2018, 12:27 PM
Apex killer! Group: Members Posts: 23,589 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
In a fairly tuned suspension, I’d make adjustments with tire pressure. 1psi out of the rear.
Your car should step out in the wet. It’s as if you added 700 HP or were driving 20 MPH faster. You can’t compare the two situations. Only same day, same tire same course. |
falcor75 |
May 21 2018, 11:00 PM
In a fairly tuned suspension, I’d make adjustments with tire pressure. 1psi out of the rear. Your car should step out in the wet. It’s as if you added 700 HP or were driving 20 MPH faster. You can’t compare the two situations. Only same day, same tire same course. I did autocross it in the dry last summer too its just that I only had the video of the rainy event. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 11:12 AM |
