Fuel pump help, Please |
gster |
May 19 2018, 02:55 PM
Newbie Group: Members Posts: 11 Joined: 15-April 17 From: canada Member No.: 21,021 Region Association: Canada |
I've installed an Airtex pump on the car as recommended by many.
The car does run but terribly.... I hope I've installed correctly and put the "T" adapter in the right place. The fuel line from the tank goes to the filter then to the pump. The pump output line is then T-eed to the other 2 lines.... Have I got this wrong? Is the filter restricting flow? The car has been sitting awhile and I've put fresh gas in. Otherwise nothing has changed. Any help is appreciated. |
ClayPerrine |
May 19 2018, 03:02 PM
Life's been good to me so far..... Group: Admin Posts: 15,454 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
There should NOT be a T fitting when using the airtex pump. The brass fitting on the fuel pump should connect to the filter. The other side of the filter should connect to the big line on the tank. The return line from the engine should connect directly to the smaller line on the tank.
If you put in the T fitting, you are dumping fuel pressure. That will make it run terrible. |
Lo-Fi Version | Time is now: 13th May 2024 - 02:54 AM |
