Fuel pump help, Please |
gster |
May 19 2018, 02:55 PM
Newbie Group: Members Posts: 11 Joined: 15-April 17 From: canada Member No.: 21,021 Region Association: Canada |
I've installed an Airtex pump on the car as recommended by many.
The car does run but terribly.... I hope I've installed correctly and put the "T" adapter in the right place. The fuel line from the tank goes to the filter then to the pump. The pump output line is then T-eed to the other 2 lines.... Have I got this wrong? Is the filter restricting flow? The car has been sitting awhile and I've put fresh gas in. Otherwise nothing has changed. Any help is appreciated. |
TheCabinetmaker |
May 20 2018, 11:23 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I second dumping the braided hose. Bad news. Not ethanol rated. Pic makes no sense. The return line should go back to the tank, not the pump. What is the other end of that hose attached to, and what line do you have to the return hard line at the tank?
Lo-Fi Version | Time is now: 13th May 2024 - 03:00 AM |
