Installing reproduction rocker panels, Are there holes on both ends of the rocker panel? |
buck toenges |
May 19 2018, 08:59 PM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
Are there suppose to be holes on both ends of the rocker panels for bolts and rubber bushing to connect the front of the rear fender and the back of the front fender? The reproduction rocker panels don't have them. I figure that it is better to drill them into the rockers when you fit them but I am not sure.
Thanks, Buck |
76-914 |
May 19 2018, 10:00 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Glass or steel? I recently installed a set of fiberglass and needed to drill for the end attach bolts. (IMG:style_emoticons/default/beerchug.gif)
wysri9 |
May 21 2018, 04:01 AM
Member Group: Members Posts: 199 Joined: 23-August 13 From: Aberdeen, Scotland Member No.: 16,291 Region Association: England |
I also have a set of fibreglass rocker panels to install - would love to see a picture or two of the fixings you have..... (IMG:style_emoticons/default/smile.gif)
GeorgeRud |
May 21 2018, 08:58 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Mount the rockers so the fender openings match up, then you can use the fender to see where to drill for the attachment. If you have flares, you just need to pick a spot that’s handy. There is a small spacer between the body and the rocker panel as well.
Lo-Fi Version | Time is now: 5th May 2024 - 10:41 AM |
