Djet Mixture Issues, Runs lean then rich |
dlee6204 |
May 20 2018, 04:39 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I'm attempting to get my car running correctly but am seeing some odd results in the AFR. Im seeing two extremes in the AFR during the warmup process.
Backstory: I acquired a 73 2.0L that I've known for some time. The previous owner converted to carbs because the original FI wouldn't run quite right when warm. The car ran great with carbs. I refreshed the motor, rebuilding the top end, and made it a 2056. At the same time I installed the original FI to get it working again which is the stage I'm at now. I'd like to see consistent results before I start tuning the MPS for the larger displacement. During the first 6 minutes of start up/driving the cars runs way lean. Idle mixture is 16+. Cruise afr is 15+. WOT starts at 11.5 and ends at 13.5ish. After 6-7 minutes of running it's like a switch is flipped. Afr reading across the board is less than 10.5. I can get it to idle around 12 but that is with the ECU knob at full lean Some more notes.... -CHT is new. Measures approx 2200ish at 70 degrees. Once warm it is approximately 50 ohms. - Intake temp sensor measure 180ish at 75 degrees. -Wiring harness is a brand new refurbished harness from Bowlsby -Mps holds vacuum. I even opened it up and checked the diaphragm. No cracks. I also checked the resistance of the coils and it checked ok. -ECU matches the MPS -Injectors were sent out to be tested cleaned. - I've driven maybe 20 miles on this setup since refreshing the motor. -I see the mixture change after 6-7 minutes whether it's idling or I'm driving -I can plug the AAR and I still see the same results. -I adjusted the TPS with no change. Anyone have any additional advice or theories as to what's going on? |
JeffBowlsby |
May 20 2018, 10:32 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Faulty CSV maybe? If its intermittently leaking, that may explain the richness. Take it out of the fuel loop by clamping the fuel line and see what happens.
Lo-Fi Version | Time is now: 18th May 2024 - 11:20 PM |
