Djet Mixture Issues, Runs lean then rich |
dlee6204 |
May 20 2018, 04:39 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I'm attempting to get my car running correctly but am seeing some odd results in the AFR. Im seeing two extremes in the AFR during the warmup process.
Backstory: I acquired a 73 2.0L that I've known for some time. The previous owner converted to carbs because the original FI wouldn't run quite right when warm. The car ran great with carbs. I refreshed the motor, rebuilding the top end, and made it a 2056. At the same time I installed the original FI to get it working again which is the stage I'm at now. I'd like to see consistent results before I start tuning the MPS for the larger displacement. During the first 6 minutes of start up/driving the cars runs way lean. Idle mixture is 16+. Cruise afr is 15+. WOT starts at 11.5 and ends at 13.5ish. After 6-7 minutes of running it's like a switch is flipped. Afr reading across the board is less than 10.5. I can get it to idle around 12 but that is with the ECU knob at full lean Some more notes.... -CHT is new. Measures approx 2200ish at 70 degrees. Once warm it is approximately 50 ohms. - Intake temp sensor measure 180ish at 75 degrees. -Wiring harness is a brand new refurbished harness from Bowlsby -Mps holds vacuum. I even opened it up and checked the diaphragm. No cracks. I also checked the resistance of the coils and it checked ok. -ECU matches the MPS -Injectors were sent out to be tested cleaned. - I've driven maybe 20 miles on this setup since refreshing the motor. -I see the mixture change after 6-7 minutes whether it's idling or I'm driving -I can plug the AAR and I still see the same results. -I adjusted the TPS with no change. Anyone have any additional advice or theories as to what's going on? |
dlee6204 |
May 21 2018, 11:27 AM
Possible progress!
On my lunch break today I rechecked a few things and then went on the hunt to see if I had a spare 037 ECU. Turns out I did! I swapped the ECUs, started it up, and let it warm up. While cold, the idle mixture was hovering around 16 and after about 10 minutes it only dropped to 14 and that’s where is stayed so it didn’t go full rich this time. I didn’t go for a test drive but will do that when I get home tonight. Hopefully I now have a reliable baseline so I can start tuning. |
Lo-Fi Version | Time is now: 27th May 2024 - 12:00 AM |
