HD Rocker Studs, tight fit for some assemblies |
nditiz1 |
May 22 2018, 07:23 AM
Senior Member Group: Members Posts: 1,177 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
When upgrading to the 8mm studs are people having to ream out the rocker shaft and blocks slightly to have them fit?
Some of my rockers assemblies fit and some are tight and don't. |
Mark Henry |
May 22 2018, 07:33 AM
nditiz1 |
May 22 2018, 07:36 AM
When upgrading to the 8mm studs are people having to ream out the rocker shaft and blocks slightly to have them fit? Some of my rockers assemblies fit and some are tight and don't. Yes, just find the same size drill bit and ream it through several times. Thanks Mark just wanted to be sure. |
Mark Henry |
May 22 2018, 08:59 AM
Ream it with the mount block and shaft together. It will still be tight.
Lo-Fi Version | Time is now: 28th April 2024 - 01:06 PM |
