FS: Wolfsburg Butterfly, 914 Euro horn button 914.613.805.12 |
type47fan |
May 24 2018, 11:35 AM
It Looks Better In Person. . . Group: Members Posts: 860 Joined: 17-September 03 From: Carlsbad, CA Member No.: 1,170 Region Association: Southern California |
FS: $125.00, plus shipping and fees.
What says NARP better that a butterfly horn button with the VW Wolfsburg crest molded into it? Interesting note: The Porsche crested butterfly horn button and this one share the SAME part number in the PET. Excellent condition, includes the mounting lugs with the later horn spade tab. (The top picture was taken with a flash to highlight the details. The finish is not as shiny as the picture shows. The bottom picture better represents a naked eye view.) Thanks for looking! |
Tom_T |
May 24 2018, 12:23 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Wayne -
IIRC that's the same p/n because they used it on the European/ROW 914's, which were marketed as VW-Porsche & the /4's were sold there by VW dealers with that horn pad. Maybe some of the Euro-zone members can confirm that. Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
defianty |
May 24 2018, 01:19 PM
Senior Member Group: Members Posts: 659 Joined: 9-August 06 From: Essex, UK Member No.: 6,621 Region Association: None |
Wayne - IIRC that's the same p/n because they used it on the European/ROW 914's, which were marketed as VW-Porsche & the /4's were sold there by VW dealers with that horn pad. Maybe some of the Euro-zone members can confirm that. Can confirm (IMG:style_emoticons/default/biggrin.gif) |
type47fan |
May 24 2018, 01:32 PM
Wayne - IIRC that's the same p/n because they used it on the European/ROW 914's, which were marketed as VW-Porsche & the /4's were sold there by VW dealers with that horn pad. Maybe some of the Euro-zone members can confirm that. Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// Hi Tom, I understand and agree with you. My initial surprise comes from years of personal experience in complex manufacturing, where each discrete part was controlled through the process with an identifying number that set it apart from all others. In this example, the butterfly (sub-assembly) frame casting has a number that tells us more about its origin: 901.613.805.0 Obviously, the manufacturing team felt that there was no need to assign a separate, unique number for a relatively minor item that could be controlled in another way. Even though, depending on with whom you are speaking, the finished parts are technically not interchangeable. Good discussion. Thanks for engaging. Cheers, Wayne |
Tom_T |
May 24 2018, 09:28 PM
Hi Tom, I understand and agree with you. My initial surprise comes from years of personal experience in complex manufacturing, where each discrete part was controlled through the process with an identifying number that set it apart from all others. In this example, the butterfly (sub-assembly) frame casting has a number that tells us more about its origin: 901.613.805.0 Obviously, the manufacturing team felt that there was no need to assign a separate, unique number for a relatively minor item that could be controlled in another way. Even though, depending on with whom you are speaking, the finished parts are technically not interchangeable. Good discussion. Thanks for engaging. Cheers, Wayne Wayne, Usually that trailing xxx.0 is the defining sub-part number, with .0 or .00 being the first in the series, so that above pic makes sense, & maybe the Porsche Crest butterfly is/was .1 or .01. They did a similar thing on the 914/4 4-lug wheels pre-73 non-hubcentric were ending in xx.00, & `73-76 were xx.01 for hubcentric At least you have confirmed for your sale that it's the Euro/ROW one, for anyone looking to restore a 914/4 from those markets. PS - More of a conundrum is that the 914 PET Parts Manual lists it as #31 on Illustration 403-05 as p/n: 914.613.805.12 - whereas yours is p/n: 901.613.805.0 which is an early SWB 911 p/n - so perhaps it was an early 70 914/4 until they got 914 versions .... or perhaps somebody had it recovered with the Wolfsburg Crest from an older 911 - not sure anyone can know at this point. GLWTS! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Lo-Fi Version | Time is now: 2nd May 2024 - 02:25 PM |
