alternator belt, keeps flying off |
mobymutt |
May 24 2018, 04:30 PM
Senior Member Group: Members Posts: 550 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
Belt flew off last 2 out of 3 drives. I'm assuming it just needs to be tighter, but are there any other potential causes?
76-914 |
May 24 2018, 04:48 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,501 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
How does it sit in the pulley's. Flush, down or up? 1/2" slack in the belt when squeezed? (IMG:style_emoticons/default/beerchug.gif)
mobymutt |
May 24 2018, 05:07 PM
How does it sit in the pulley's. Flush, down or up? 1/2" slack in the belt when squeezed? (IMG:style_emoticons/default/beerchug.gif) I believe it sits down in the pulley. I had a more experienced friend tighten it the second time, and I think the 1/2" slack when squeezed is what he was going for. Would it be possible that the alternator seizes when hot? |
Spoke |
May 24 2018, 05:21 PM
When the belt was off, did you spin the alternator by hand to see if there was binding or bearing sounds?
iankarr |
May 24 2018, 05:33 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
That happened on mine...the pulley turned out to be cracked.
Rand |
May 24 2018, 05:54 PM
Pulley alignment causes this. Check all the mounting brackets/bolts first to make sure nothing is loose or broken.
TheCabinetmaker |
May 24 2018, 06:18 PM
An old customer bought a 914and drove it for 2 years with no problems. One day it threw the belt and I put a new one on and it came off the next day. The pulley was on backwards and out of align. It took that long to throw it off. I've also seen one with a Ford pulley. As for yours, its probably loose and misaligned
mobymutt |
May 24 2018, 06:40 PM
Ok, I do think the pulley might be a bit sloppy, I'll check it out.
I just found my belt on the side of the road, split. So next question, how long can I drive without the alternator charging the battery? |
ConeDodger |
May 24 2018, 06:55 PM
Apex killer! Group: Members Posts: 23,586 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Alignment is very important. I powder coated all of my engine parts including a washer that acts as a spacer. It kept throwing belts. I left it with McMark and he had to realign the pulleys.
914Sixer |
May 24 2018, 08:38 PM
New pulleys over on theSamba.com under 411/412 Parts $40
Bartlett 914 |
May 25 2018, 06:43 AM
Pulley alignment causes this. Check all the mounting brackets/bolts first to make sure nothing is loose or broken. (IMG:style_emoticons/default/agree.gif) I had this happen to me. The bracket had been loose for some time. It actually damaged the fan housing. The movement of the loose bracket wore the fan housing so when tight, it would not be aligned properly |
iankarr |
May 25 2018, 07:10 AM
Ok, I do think the pulley might be a bit sloppy, I'll check it out. I just found my belt on the side of the road, split. So next question, how long can I drive without the alternator charging the battery? Depends on how fast you’re going, whether you’re turning the engine on and off, and the condition of the battery. Probably not more than an hour of normal driving. Here’s a pic of my cracked pulley (and the incorrect belt the PO installed) |
rjames |
May 25 2018, 09:27 AM
I'm made of metal Group: Members Posts: 3,932 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
How often should the belt be changed? I have no reason to think mine needs replacing other than it's probably been on there for 20 years.
rhodyguy |
May 25 2018, 10:29 AM
Contact 914Sixer, Mark, and see if he has anymore of the correctly sized belts. I bought 2 of them. Cheaper than at my FLAPS with shipping included. I figure I'm set for life.
1adam12 |
May 25 2018, 10:39 AM
Member Group: Members Posts: 209 Joined: 25-May 17 From: Chino Hills, CA Member No.: 21,132 Region Association: Southern California |
Check that alignment like most have already mentioned. Did you happen to recently reinstall your engine tins? Make sure your alternator is not bottoming out on the tin that's on the back side of the cylinder head. I just had this issue when I reinstalled the tins and had to remove and reinstall that piece correctly. Luckily I caught it before starting up the engine.
mobymutt |
May 25 2018, 11:03 AM
Check that alignment like most have already mentioned. Did you happen to recently reinstall your engine tins? Make sure your alternator is not bottoming out on the tin that's on the back side of the cylinder head. I just had this issue when I reinstalled the tins and had to remove and reinstall that piece correctly. Luckily I caught it before starting up the engine. Yeah, I had the whole engine apart last summer... |
914Sixer |
May 25 2018, 01:28 PM
Yes, I have 5 more correct belts left.
PanelBilly |
May 25 2018, 02:49 PM
914 Guru Group: Members Posts: 5,805 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I had this same problem years ago. It was the pulley that had a small fracture in it. I took it apart several times changing the belt and looking at alignment. When I finely studied the pulley I found the crack.
mobymutt |
May 25 2018, 07:32 PM
mobymutt |
May 25 2018, 07:37 PM
My pulley actually looks to be in good shape.
As for the alternator, I spun it by hand with the belt off. It spins freely and smoothly, but it does have a squeak. Probably not a good thing. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:09 PM |
