911 oil temp / pressure gauge, how did you mount the pressure sensor? |
falcor75 |
May 24 2018, 11:01 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
I installed a 911 oil temp and pressure gauge this Winter.
I didnt want to hack up my engine tins to mount the sensor in the stock location so I made bracket and mounted it on the fan housing where the stock coil sits and connected it to the oil pressure port with a piece of steel braided hose with the correct end fittings. It works well and doesnt leak but I've noticed that in long sweeping left hand turns I loose oil pressure, it never goes to zero but once or twice the light flickered on and then immediatly turned off again. Do you think this could be a sensor location thing or perhaps an issue with my tuna can installation? |
jcd914 |
May 25 2018, 12:59 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I have never experienced or heard of an issue like this with oil sender mounted remotely.
I have seen a few that came loose or lost their the ground. I would check to make sure the sender is solidly mounted and has a good ground. If there is nothing there to attribute yoyr symptoms to I would look at the tuna can install. Make sure the pick up tube extension fits tight and goes all the way down to the bottom of the tuna can. I always ran mine 1/2 quart over full of oil in addition to running a tuna can. Jim |
Lo-Fi Version | Time is now: 4th May 2024 - 05:32 AM |
