911 oil temp / pressure gauge, how did you mount the pressure sensor? |
falcor75 |
May 24 2018, 11:01 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
I installed a 911 oil temp and pressure gauge this Winter.
I didnt want to hack up my engine tins to mount the sensor in the stock location so I made bracket and mounted it on the fan housing where the stock coil sits and connected it to the oil pressure port with a piece of steel braided hose with the correct end fittings. It works well and doesnt leak but I've noticed that in long sweeping left hand turns I loose oil pressure, it never goes to zero but once or twice the light flickered on and then immediatly turned off again. Do you think this could be a sensor location thing or perhaps an issue with my tuna can installation? |
bdstone914 |
May 25 2018, 08:35 AM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Not the sender,
Do you have a windage tray installed in the engine to reduce oil shifting in turns? You are not picking up oil. |
Lo-Fi Version | Time is now: 24th April 2024 - 07:31 PM |
